Currently I'm struggling using OSC Slope. Normally I'm using OSC Slope at the very end, to finally polish the patch. Accessing OSC Slop is a bit pita, since you need to touch OSC controls. I use sync button for the same twice, then go to the second tab and finally adjust the slope. It is not very intuitive if you need to adjust all three slopes.
Would it be possible to have all three slopes at one page? The 4th tab in Misc. Params is currently empty and could be used for the same.
More general and actually my preferable solution would be to have this "Prophet 12 mode", where you can scroll through OSC- and also some other parameters using the most left encoder over the screen and adjusting parameters using encoders 2,3, and 4.
BTW. if you have any better ideas for easier access of OSC SLOP - please share! :-)
