The problem is that the Prophet-6 can't be simply extended with further features of this kind. It has been possible to add effects and a control indicator (the dot that shows up in the display after you changed a value) as of the latest firmware, but what you are asking for would require at least two additional parameter controls (for activating a delay and setting a delay time) that could maybe be combined in one knob, an additional LFO, or an auxiliary envelope. With the Prophet-6 consciously following the "what you see is what you get" approach, meaning that the display only offers access to control global settings, any functionality that would require the enhancement of a menu does not work because there is no menu. And the hardware can't be changed anymore. If anything, maybe a certain combination of buttons could be part of the solution. This, however, would be diametrically opposed to the Prophet-6's design philosophy, which doesn't make use of dual functions with regard to any of its parameters.
