OB6 vco frequency readout incorrect
« on: July 21, 2020, 10:58:13 AM »
Hello,
On our OB6, the readout of the pitch is wrong. The only way to correct it seems to be:
1. Hold down (for example) the A key and tune both oscillators until unless the readout says 'A' on each.
2. Globally transpose up by 3 steps
3. Do this for every single patch.
No amount of globals+0 gets the synth to align itself, only these manual steps correct it.
Without global transpose +3 the LED display always reads 2 steps down from where it should.
Is this a bug? The last firmware update did not fix it- we are running version 1.5.5
Anyone else have the same issue?
Re: OB6 vco frequency readout incorrect
« Reply #1 on: August 07, 2020, 10:22:02 AM »
Have you had a look at the pitch bend wheel to make sure it isn't behaving badly?
