How to fix SLOW PROGRAM (PATCH) CHANGES??!!
« on: June 14, 2020, 11:09:57 AM »
I use Ableton for automatic program(patch) changes on the my prophetXL and usually everything works very smoothly but there are some patches that take a couple seconds to fully load and obviously then I'm late on the changes in a song.
Even without Ableton connected, some programs(patches) on the prophetXL still take much longer than others.  Wondering if someone knows why this is and if i can edit anything in these patches so they load faster?
Re: How to fix SLOW PROGRAM (PATCH) CHANGES??!!
« Reply #1 on: June 14, 2020, 01:49:12 PM »
The instrument samples used in the patch should be the primary reason why some will load slower than others.  The only tip that leaps to mind without a lot more work is to check to see if you're only using Layer A or B and if not, save a copy of the preset with the instruments in the layer you're not using set to Instrument # 1 (silence) instead.
« Reply #2 on: June 15, 2020, 10:09:41 AM »
Ok thanks, I'll give that a shot.  I actually updated my firmware which helped a lot! However, now all midi cuts out after a few program changes.......sounds like a common bug with the new firmware.  So, now i have much bigger problems than just a small delay as I need to find the original firmware. Currently on hold with customer support. UGGGGGGGGH whack-a-mole of life hahaha.
