Why is it that the LFO's sync speed is depending on the internal sequencer steps instead of midi clocked steps?
Let's say I want to use a triangle with a 32 step speed I will need to put the internal sequencer in trigger mode when using an external sequencer.
If I leave it on normal mode the LFO will reset with every note played from the external sequencer.
