MIDI OUT not working even after the update
« on: May 13, 2020, 06:41:15 AM »
Hi! I'm using ableton live 10 and midi out is not working if I switch to Local Control OFF. The rest of my synths works without problems (Moog Subsequent37, Korg Prologue 16, etc)
What can I do, I have updated the firmware and still not working. It is frustrating I tried everything I now have 6 hours of trial and error.
Please help!
Petur
  • 20
  • Pro 3 - Rev 2
Re: MIDI OUT not working even after the update
« Reply #1 on: May 13, 2020, 08:22:05 AM »
Hi, go to Globals and check if :
MIDI Control Enable is : ON
MIDI Out Select is on : USB or MIDI DIN - depends on your Midi Connection
Also, you have to create a Midi Controler in Live (Pro 3)
Hope this helps.
« Reply #2 on: May 13, 2020, 08:30:22 AM »
Hope this helps.
Hi Petur!
Is is exactly like you said and no sound from midi in ableton...
I also get some weird pops and clicks when using the Pro 3 in sequencer mode even outside ableton. I guess they come from the effects section or I dunno. They are present even in the some of the stock patches.
so sad...
« Reply #3 on: May 13, 2020, 09:31:33 AM »
Hi Petur!
so sad...
[/quote]
Let me know your settings and I will try do the same in Live exactly as you have it.  Yes the crackle is from the updated firmware when effects are used, supposedly will be fixed in the next update.
