RESOLVED: Pro 3 sending CC7 when moving various knobs
« on: May 12, 2020, 03:47:10 PM »
Hello all - I recently got a Pro 3 and I'm trying to record MIDI performance data with it in NRPN mode.  I'm completely new to using NRPN so that fact might be part of my problem.
When I record MIDI data from the Pro 3 in Cubase and move the filter cutoff knob (and other knobs) I get CC7 data along with four other CCs.  It appears the CC7 data contain some portion of the NRPN data.  My understanding of NRPN is that it uses four MIDI CCs to send data - I'm getting five CCs.
Also, I don't think CC7 is one of the intended four CCs because it controls volume.  So when I play the track back from the Cubase MIDI track I get a bunch of volume jumps when none was recorded.  I can delete the CC7 data but the filter adjustments still are not correct.
So what the Pro 3 is sending via NRPN clearly is not correct but I'm not sure how to fix the problem.
Any help on this issue?
Thanks in advance,
rgames
« Last Edit: May 14, 2020, 11:57:57 AM by cbmd »
Re: Pro 3 sending CC7 when moving various knobs
« Reply #1 on: May 12, 2020, 09:07:32 PM »
Solved - appears to be fixed with update to OS 1.0.2.3.
