Just got the Rev 2 but having an issue where when I press the play button from my DAW the oscillator 1 frequency goes to a very high pitch. If I manually adjust the frequency back to where it should be and press play again the result is the same. Only the first oscillator is effected by this and I don't really understand what the issue is, so any help would be appreciated. As is the Rev 2 is pretty much entirely unusable because of this issue. The firmware is up to date. The daw being used is FL Studio with the Rev 2 on port 0 channel 2. It is being controlled via USB.
