Totally possible and easy.
Option 1: use HxD hexa editor to view the bank file. Each bank file contains 100 programs 0-99 starting with F0 and ending with F7. Which one do you want? Either I can send it to you or you can extract it yourself from the bank file.
Then you use Midi OX to send the extracted file to the synth.
You need to decide before where you want to send it and adapt the file (in buffer or directly in a bank/program).
I can explain you how to do that as well.
Option 2: use my free Pro 2 editor and librarian.
https://ctrlr.org/dsi-pro2-editor-and-librarian/Go to Programs library tab. Load the complete bank in D1 or D2 (which is on your disk). Select the program you want to extract (will be highlighted in blue as Source program). On the right side, select "Load from disk to buffer" as Program action then Proceed and it will go in your synth's buffer.
