Sequencer Feature Request
klstay
  • 6
  • Retired Old School Modular Duffer
« on: April 30, 2020, 08:10:38 AM »
Would it be possible to have at least one of the tracks be set to a "playback control" mode where each press of the step buttons cycled it between play/reset to "start" step/skip/stop as well as change toggle button color. Ideally you could select for that track whether you wanted each press to cycle through play/skip, play/reset, play/skip/reset, play/skip/stop, play/reset/stop, or all 4. This is VERY powerful on a modular 960 with reset option per step modded onto it.
Being able to decide which other tracks were controlled by this one would be a nice bonus. Also, being able to dedicate sixteen "white" keys from the keyboard to trigger the cycling through play/reset/skip/stop would be fantastic. Finally (as if this had not already been enough to beg for) being able to hold down a "function" key while pressing which step from this "playback control" track would be set as the start/reset to step would be the cherry on top!
If it cannot interface with modular, what good is it?
