Loose Pitch Bend wheel?
« on: April 28, 2020, 10:54:11 AM »
http://innerportalstudio.com/downloads/Pro3PB.MOV
Does anyone else have an issue with their PB Wheel being very loose?  Mine has been making an intermittent grinding noise since I got it, but today I noticed the wheel itself has become VERY loose in the case.   Anyone from Sequential know how easy it is to access this if I open up the case?  I'm pretty handy and have opened up many of my synths in the past to make small fixes like this, I just don't want to waste the time trying if it's not something I can access easily.
Side Note: the cutoff knob on my SE Pro 3 was also incredibly loose, it was barely attached to the front panel.  That happily was an easy fix and now it's fine.
Re: Loose Pitch Bend wheel?
« Reply #1 on: April 28, 2020, 01:20:29 PM »
Have the standard version and mine are fine , filter knob too.
« Reply #2 on: April 30, 2020, 03:15:25 PM »
Mine came with a loose mod wheel. It is an easy fix.  remove the 4 or 5 screws holding the housing, I luckily had a very thin wrench the correct size.  You'll see.
« Reply #3 on: April 30, 2020, 03:30:55 PM »
Thanks, in contact with sequential now about it. Appreciate the advice.
