Cutoff knob not working right...
« on: April 26, 2020, 12:05:58 PM »
Ive noticed when I turn the cutoff nob there is a major delay.. and it very slowly starts catching up to where i set it. Any one else having this issue?
Re: Cutoff knob not working right...
« Reply #1 on: April 26, 2020, 02:33:57 PM »
Are we talking keyboard model here? Is there MIDI involved? Some information on the set up would help people diagnose.
« Reply #2 on: May 06, 2020, 08:34:28 PM »
Ah yes, true. Yeah its the keyboard version. 8 voice. Midi going into my daw. It's never acted like this before.
shiihs
  • 97
« Reply #3 on: May 13, 2020, 04:41:19 AM »
Just to exclude the obvious: does it still happen if you remove the midi connection to your DAW?
gear: prophet rev2 16 voice, yamaha gt-2, casio wk-7600, Roland Integra-7, supercollider, ardour
links:
« Reply #4 on: May 15, 2021, 09:54:06 AM »
It seems that I have the exact same problem: cutoff knob and lfo-amount knob no longer work properly, the reaction is extremely delayed, a smooth turn of the knob results in slow or unpredictable parameter changes.
I am not sure whether it is a software-based problem or the two knobs are physically damaged, as the corresponding parameters can still be controlled via the value knob.
I am using the latest firmware and have recalibrated the synth several times, no midi signals or expression pedals were involved.
Has anyone found a solution yet? A support ticket is probably the best idea ...
CPN37
« Reply #5 on: May 20, 2021, 01:28:33 AM »
Which Pot Mode are you using?
Sequential Prophet 5 Rev4, Sequential Circuits Pro One, Sequential Prophet Rev2-8, ARP Pro Soloist, Roland Jupiter 4, Roland Juno 60
« Reply #6 on: May 20, 2021, 11:50:09 AM »
Pot Mode is relative. I am in contact with sequential but the recommendations for solving the problem have not worked so far. I will keep you up to date
« Reply #7 on: May 22, 2021, 10:17:59 AM »
I still havent fixed my issue either. They said I should take apart the chip and send to them to fix the knob issue. I just dread doing something like that. Is my unit going to be useless during the time it takes for them to repair it?
let me know if you figure out a different way to fix this..
« Reply #8 on: May 31, 2021, 03:04:35 PM »
I see that so far post #3 has been ignored, but I'm betting the issue is simply that when you have it attached to DAW, it is reflecting MIDI back too slowly, so your parameter changes (not just filter cutoff) are constantly being moved back from where Rev2 thinks they should be, making it appear that they are going back and forth to some degree. If so, this is not an issue with your Rev2, and you have to design your workflow to deal with this limitation of MIDI protocol.
