prophet xl not responding after os update from 2 to 2.2
« on: April 25, 2020, 03:19:24 AM »
just taken delivery of this so I decided to update the OS and followed the update procedure
all was fine, I did as it said when the update had finished ,and restarted,
now all I get is that black and white grain screen on the main and effects screen and nothing on the sample playback machine
any ideas anyone?
I have emailed support but it's a weekend :(
blewis
  • 218
Re: prophet xl not responding after os update from 2 to 2.2
« Reply #1 on: April 25, 2020, 04:43:24 AM »
You’re going to have to manually load a SysEx version of the OS through the MIDI DIN input.
Are you setup to do that?
« Reply #2 on: April 25, 2020, 06:31:39 AM »
yes I can do that, but where do I get the SysEx data?
thanks
John
« Reply #3 on: April 25, 2020, 09:56:14 AM »
There's still a .syx file for the beta 2.1.3 in this post Prophet X BETA OS - v2.1.3. You could try using that SysEx file and then attempt the upgrade to 2.2.0.0, again. Instructions on using bootloader mode are in the second post of that thread.
https://1403.slantedhall.com/ | https://slantedhall.com/
blewis
  • 218
« Reply #4 on: April 25, 2020, 10:15:39 AM »
I have the 2.2.0 SysEx file. If you want to private message me your e-mail, I can send it to you.
I've had to use it, and I've had to supply it to someone else under similar circumstances before too.
« Reply #5 on: April 25, 2020, 11:18:50 AM »
I can't get thru the verification process even though I get the answers right
my email is
jwkeys@mac.com
blewis
  • 218
« Reply #6 on: April 25, 2020, 01:39:27 PM »
Check your inbox
my email is
<removed>
