Sequencer track lengths ?
« on: April 23, 2020, 02:31:09 AM »
Are these defined by how many notes you input in Lane one , or individual ?
Also
Can you change length after you have recorded ?
Re: Sequencer track lengths ?
« Reply #1 on: April 23, 2020, 07:59:07 AM »
Also
Default is based on the note steps but you can have a note sequence track of 9 steps and a filter sequence track of 14 and change those after recording. You can also change the number of steps while the sequencer is running as a performance tool.
« Reply #2 on: April 24, 2020, 01:07:22 AM »
To change the length of a track after recording, press 'reset' while holding down the step button of whichever step you want to be the final one for that track. The letter R will appear in the next step along.
Pym
  • 152
« Reply #3 on: April 24, 2020, 10:43:15 AM »
Track one is considered a soft master length. If you change the length of track 1 and all other tracks are the same length, it changes all of them to the same length. If even one of the tracks is a different length, we assume you wanted to do different lengths and only track 1 reset point is changed
And as others mentioned, hold a step button and hit reset to change the reset point of the track you have selected
Also
Sequential
« Reply #4 on: May 28, 2020, 07:01:58 AM »
does that only work on notes , because I cannot get the filter to do that.
Oh wait you have to put in a note as well otherwise it does nothing, I see.
« Last Edit: May 28, 2020, 07:03:45 AM by h4ndcrafted »
