Arpeggiator Gate Length
« on: April 19, 2020, 10:12:21 AM »
I have a fairly new Rev2 and decided to use the arpeggiator on a track, but it's too staccato. Does anyone know if there's e a way to change the gate length? Can't seem to find it  in the settings or manual.
Re: Arpeggiator Gate Length
« Reply #1 on: April 19, 2020, 12:11:49 PM »
It’s set to I believe 50%. I end up adjusting the envelope accordingly.
« Reply #2 on: August 16, 2023, 04:01:23 PM »
Reviving an old thread, I'm having this same issue.
I tried adjusting this different envelopes, as guyaguy suggested, but that didn't work.
One work-around is to increase the release on amp envelope, but that's not what I'm trying to do.
• I'm trying to use the Glide with the Arp, but the length of the note won't connect the two notes properly (in legato fashion).
I'm not seeing the 50% length anywhere for adjustments. Maybe it's right in front of me and I can't see it.
« Reply #3 on: August 17, 2023, 03:06:35 AM »
As said it's fixed to 50%, and also mentioned in manual.
If not continuous like on Polybrute, at least settings 25,50,75% as on Prologue would be very usable. Open up for many more sounds and tempos.
« Reply #4 on: August 17, 2023, 03:39:24 PM »
Make sure you aren't trying to use one of the two "auto glide" modes. These settings are in the misc parameters menu...
