Feature Request: P12 Simultaneous edit mode for Pro-3
« on: April 19, 2020, 01:47:01 AM »
Prophet 12 Module provides a mode for simultaneous edit of a same parameter.
From P12 module manual, page 12
Tip: To edit a parameter on all oscillators simultaneously, press and briefly
hold any of the oscillator select buttons until all of them are lit. Select the
desired parameter using Prev and Next Param (Soft keys 2 & 3). Press and
hold, Hold: Edit All (Soft key 1) while adjusting one of the soft knobs. Or
use the soft knobs to edit the same parameter for each oscillator individually.
Press any oscillator button to exit.
If would be absolutely fantastic to have the same for Pro-3!
First you can see the actual parameters values and second you could get better alternative access for menu hidden parameters.  For example having SLOPE parameter for all three oscillators on display at the same time and adjusting them simultaneously encoders.
What do you think?
« Last Edit: April 19, 2020, 01:48:57 AM by alexpen »
jg666
  • 561
Re: Feature Request: P12 Simultaneous edit mode for Pro-3
« Reply #1 on: April 19, 2020, 02:34:56 AM »
This is available on the Pro2 so I'm surprised it isn't available on the Pro3.
« Reply #2 on: April 19, 2020, 02:38:25 AM »
On the Prophet 12 and Pro 2 the oscillators are identical. Not the case on the Pro 3, which may explain why the option isn’t there.
« Reply #3 on: April 19, 2020, 08:21:20 AM »
Yes, this might be the case.... However it would be very-very nice.
cbmd
  • 505
    • Sequential
« Reply #4 on: April 22, 2020, 11:19:13 AM »
There are no oscillator select buttons on the Pro 3, so there is no means to link all the oscillators by holding an oscillator select button.
Product Designer
« Reply #5 on: April 27, 2020, 03:08:12 AM »
I don't know, something like double click on SHOW button would switch to the "simultaneous mode". Touching for example "Shape" knob of one of the oscilators, will show all three shapes in display... pressing prev/next you would be able to select other osc parameters.
The point of the simultaneous mode, despite accessing the hidden menu parameters is the ability to see all three current parameters at once. OK, I'm wishing probably too much... but this would be absolutely great!
« Reply #6 on: May 04, 2020, 12:49:33 AM »
currently knob/encoders values are represented as numbers.
Since different parameters have different ranges - most of 0-127, but Cutoff 0-1023, Shapemode for OSC1/2 -127+127 or shape mode for OSC 3, etc. - it is quite cumbersome quickly understand where you are, if you load a patch for example.
Would it be possible to get the "Prophet 12"-way presentation with the knob diagram?
Alex
« Reply #7 on: May 04, 2020, 06:30:50 AM »
Would love to see this as well, as I have the same issues with the different ranges of parameters.
