Hi.
I recently bought a brand new Mopho Keyboard. It had been purchased years ago as a present and never used.
The problem is with the pitch wheel.
As soon as you touch the pitch wheel after turning it on, it detunes around a semi tone.
If I go to the patch and set P.W to 0, then move the pitch wheel, it goes back into tune.
If I set P.W to any value then hit the pitch wheel again it goes out of tune again.
Obviously either the pot is faulty (although it works fine otherwise, as in its very linear when turning it) or I need to calibrate the Mopho.
The only problem is I cant find a calibration routine. There is one for the SE and the x4 but it doesn't seem to work on the Mopho keyboard.
Any suggestions would be welcomed.
Cheers
Brett (Thedood)
