New free OpenSource Sysex Librarian - The KnobKraft Orm (with download)
Re: New free OpenSource Sysex Librarian - The KnobKraft Orm (with download)
« Reply #40 on: December 04, 2021, 02:58:15 PM »
this is a great tool, really smart design, visually it's uncluttered and you've made it easy to keep track of what's what through the imports window, very simple to keep what's on the synth and what's in the librarian discrete, I usually find librarian software confusing with this aspect. thank you for providing the opportunity to edit the tag names as well, this was thoughtful of you and much appreciated.
as others have mentioned, naturally I've gone across the user banks (I've always hated how many there were on my Rev2 to be honest) and tagged things, and naturally I now want to reorganize them so that they spread out in the user banks in a more sensible way when I'm just on hardware with no computer. Maybe like a cut/copy/paste in the main window so you could save the database configurations then dump to the synth?
but seems like you're developing this already for a v2 of the software, so kudos! one question for you, is there anywhere on the display that shows the preset number of the patch? the name is clearly listed in the rectangles, but I can't find the corresponding U#P### number, though I can do the math just by counting them in the meantime. Thanks again!
Loading just faves into the synth?
« Reply #41 on: January 05, 2022, 10:35:32 AM »
Hey y'all.... finally got into the forum.... This KnobKraft is killer, but I am easily confused.   How can I load my faves as a single bank...anyone know?   THANKS!
kris
  • 145
Re: Loading just faves into the synth?
« Reply #42 on: January 23, 2022, 10:35:53 AM »
Thank you! It's not your fault, it's mine ;-) I originally intended the KnobKraft to store all patches on the computer, like Lightroom stores all my photos. And then if you want to search for a specific patch, you just use the computer while attached to the synth. Disclaimer: I don't gig and don't need the patches in the synth's memory.
But I understood that most people probably correctly expect a bank management feature from a Sysex Librarian ;-), so this is what I'm working on now. It is a side project with only limited time available, but I hope to get there by spring!
« Reply #43 on: February 05, 2022, 09:16:35 PM »
Looks very nice but fails to open for me. Displays the Yes No window very briefly then crashes.
kris
  • 145
« Reply #44 on: February 17, 2022, 09:25:12 AM »
Hm, that shouldn't be the case? Which version/platform did you try? I was told there were some errors on Windows 7 machines with the latest build.
kris
  • 145
« Reply #45 on: February 26, 2022, 07:43:12 AM »
Which have been fixed by now, the 1.14.2 works again for Windows 7, Windows 10 of course and macOS from 10.14 onwards I believe.
Hi Aleos, sorry seeing this only now, somehow the Sequential forum doesn't do email notifications for me...
You may have tried this already, and I don't yet know if it works, but there are settings via your Profile link, near the top of the page:
Profile > Modify Profile > (Hover for a drop down menu) > Notifications
There are some settings there, including:
[ x ] Turn notification on when you post or reply to a topic
Thanks for making the Orm.  I've been using it for a while, but didn't have a Rev 2 until recently.  The new release looks good  8).  I'll try it properly over the weekend.
« Reply #47 on: July 29, 2022, 02:17:47 PM »
This reply may be too late to still be useful, but what you can do is import the bank into KnobKraft Orm, then click on a patch, which loads it into the edit buffer of the Rev 2.  You can then manually save it to where you want that particular patch to be, by pressing Write, then turning the knobs to set the bank and patch number, then pressing Write again.
It would be a bit of a chore to do that 128 times in a row, but if you do it gradually as you try the patches, it's no real hardship.
That now works in the latest release, which is 1.16.0.  There's a drop down menu to choose whether you see just the name, the name and the patch number (including the bank) or those plus the name of the second layer... You can also choose to only see the numbers, but I gather that's meant for synths that don't have patch names.
There are now two sliders for setting the number of rows and columns of patches in the Orm too  8)
« Reply #49 on: March 23, 2024, 07:13:17 AM »
Hi all!
I'm new to synth in general and struggling to get to grips with most things! I've got some sysex files that contain a single patch and I want to send them over to a particular bank and program on the Pro 3. I've got KnobKraft speaking to the Pro 3, but I can't see any obvious way to load a sysex file and send it over to replace an existing patch. I've also tried midi-ox, but that's even more confusing! Any help would be greatly appericated.
« Reply #50 on: March 23, 2024, 08:10:39 AM »
@Turak64, the way I do it on the Rev2 is to send to the Edit buffer, by clicking on the patch in the Library tab in KnobKraft, then save it manually on the synth to the bank and patch slot where I want it to go, using the synth's own menus.
You have to have your synth ticked on the Setup tab in KnobKraft, before you can click on the Library tab.  If you have more than one synth ticked in Setup, you'll also see a tab to select each one, near top right.
« Reply #51 on: March 28, 2024, 06:14:05 AM »
Many thanks for your work, Kris.
Is it possible to overwrite the factory banks with KnobKraft Orm?
Is there a manual or is it not necessary because it is self-explanatory?
I have only found the short video.
Greetings Ralf
REV2 16 Desktop
kris
  • 145
« Reply #52 on: April 15, 2024, 01:28:27 PM »
Greetings Ralf
Thanks! Actually I haven't tested it. The Rev2 has no bank dumps, each transfer into the synth addresses bank and program slot, so overwriting should either work out of the box or needs some magic trick. Have to give it a try myself.
The way you'd do it is to sync e.g. the F4 bank into the Synth Bank tab by selecting it in the tree view under "In Synth", then drag a patch into it at any place and click send to synth. It will only send changed patches back, so it would try to store a single program in the factory bank.
I don't have a better manual or video right now, for the lack of time, and I try to spend the little time I have on enhancement requests and synth adaptation, but if nobody else picks it up at some point I have to make another video or two, given the complexity of the software by now ;-)
kris
  • 145
« Reply #53 on: April 15, 2024, 01:44:17 PM »
Actually, this old thread seems to indicate that it should work just normally via sysex:
https://forum.sequential.com/index.php?topic=2023.0
so my suggestion above should work. Will try next time I setup the Rev2!
« Reply #54 on: November 09, 2024, 12:31:53 PM »
Hi, this looks exactly like what I've been looking for, I've had my Rev2 a couple of weeks and I'm new to Sysex. When I install the latest .dmg for mac and install, it says I don't have python. I've never used python either. I've read the intro post, watched the video and visited the github, but cant see any instruction. Could someone please help me out with some basic  instructions just to get it up and running? Many thanks
« Last Edit: November 09, 2024, 01:40:14 PM by Mess »
kris
  • 145
« Reply #55 on: November 10, 2024, 02:45:10 AM »
I need to find more time to fix the Python issues with Mac - on Windows, it is pretty easy to ship Python embedded in the program, the Mac is... different.
So far the best bet is to install Python 3.12 (for the latest KnobKraft versions) from the download from python.org. Use the universal binary because the KnobKraft is compiled (right now) for Rosetta (Intel), and if you install the M1 executables only it won't work: https://www.python.org/downloads/macos/
