ALWAYS BACKUP YOUR IMPORTANT WORK VIA SYSEX DUMP BEFORE ATTEMPTING ANY OS UPDATES!! It is highly unlikely to incur data loss from an OS update attempt, but always better safe than sorry. Just remember, you're never going to say to yourself "Man, I wish I'd backed that up before starting..."
The OS can be updated via USB or MIDI DIN.
We do not recommend using the following MIDI interfaces for SysEx transfers as we have had multiple users experience problems with them:
Native Instruments Maschine
Digidesign Mbox/Mbox2
Digidesign 001/002
CME U2MIDI
To check if the OS update was properly installed, go to the Global menu by hitting the 'Global' button. The OS version is displayed in the bottom right corner.
If your OS load countdown doesn't complete:
- Update your MIDI drivers for your MIDI interface to the latest or last known stable version
- Try alternate speed settings: transfer speed settings as low as 25% and as high as 100% have worked for some users when 80% did not
- Try an alternate MIDI interface. The M-Audio MIDI Sport Uno works well here and is relatively cheap
- In Windows with MIDI OX on Windows XP: Try doubling or quadrupling the Size setting to start, and halving/doubling the number of buffers
- Search google and/or forums for the company that produces your MIDI interface to see if other users are having similar problems with SysEx transfers and whether there is a solution specific to your interface
- If you are on Windows XP, try another OS or machine. Although it's not ideal, we have had less problems with Mac OSX and Windows 7. Windows XP has known issues with SysEx transfers
Main OS 1.1.0.0- Feature: User Wavetables now supported in wavetable slots 33-64 (wavetable file generator www.sequentialwaves.com)
- Bug: LFO frequency does not update reliably when in MIDI loopback using NRPNs and LOCAL CONTROL off
- Bug: Stereo Delay sync'd times do not updated correctly
- Bug: FX mix does not go full dry/wet
Main OS 1.0.3.45- Change MIDI CLOCK terminology from master/slave to out/in
- Feature: Stereo delay now ping pongs automatically if modulation applied to pan destination
- Feature: play triggers sequencer internally when local control off and seq mode set to normal
- Fixed bug: program changes received immediately following bank change LSB do not change program
- Fixed bug: tap tempo operation bug fixes and improvements
- Fixed bug: duophonic mode, pressing a single key rotates through oscillators
- Fixed bug: cue program held, program and bank soft displays are reversed per soft knob operation
- Fixed bug: playlist on, pressing write causes freeze
- Fixed bug: all seq param tracks set to incorrect value when basic patch used
- Fixed bug: off by one receiving program change messages
- Various other improvements and fixes
Main OS 1.0.3.26- Feature: MIDI ARP/SEQ NOTES global parameter sets arp and seq track 1 to send MIDI note data to the MIDI output
- Feature: Sequencer destinations added for MIDI note and CC output to USB
- Fixed Bug: Sequencer NRPN on/off message causing feedback loop in Normal/Gated Sequence Modes
- Fixed Bug: Clicks in FX path
- Fixed Bug: External MIDI clock sync improved
- Fixed Bug: Gate out now transmits 0-10V, not 0-5V
- Fixed Bug: Freeze when playlist active and track select pressed
- Fixed Bug: Sequencer steps initialized with velocity 1 when basic patch or erase track used saved as rested steps
- Fixed Bug: Arp on, Sequencer in Normal mode and in playback, both arp and sequencer trigger notes
- Various other fixes and improvements
- Known Bug: Tap Tempo updates BPM on every press
Main OS 1.0.2.3- Feature: New Sequencer Double Tap Step Edit Record Mode:
Double tap RECORD to enter this mode. The RECORD button will begin blinking. While in this mode, hitting a step button plays the synth using those step parameters.
Holding the step and moving a param changes the param on the step. So, you can quickly listen to and edit a step by hitting, holding and moving the param, then hitting the step again. Exit this mode by pressing RECORD again. - Feature: Tempo reference added to main program screen
- Feature: Duophonic Mode:
With paraphonic on, setting osc 3 low freq on sets paraphonic mode to duophonic mode - Feature: Note priority improvement in paraphonic mode: Held low note is never stolen
- Bug Fix: USB hot swap issues resolved
- Bug Fix: Occasional hung notes in paraphonic mode
- Bug Fix: Small tweak/improvements to sequencer operation
- Bug Fix: Increased modulation range to Pan destinaion
- Bug Fix: Playlist on, List and Set soft knobs do not update selected list/set until a soft button is pressed
- Bug Fix: Various other small bug fixes
Main OS 1.0.1.1**Reset Globals after the update completes!**
- Feature: New Globals organization
- Feature: Front Panel controls now active in Playlist mode
- Feature: Added handling for playback of ratchets in reverse direction
- Feature: Added "Erase All Tracks" command to Sequencer
- Bug Fix: Corrected MIDI CC lables in mod matrix
- Bug Fix: USB MIDI param data transmission errors
- Bug Fix: Sequencer CV out scaled incorrectly, now goes -10V to 10V
- Bug Fix: Wave Reset not functioning on Osc.3
- Bug Fix: Pitch pots don't operate correctly in Relative pot mode
- Bug Fix: A few params not updated correctly when edit buffer dump received
