Time based effects not syncing correctly when set to Slave with no start/stop?
I think this might be a bug but haven't worked it all out yet.
Basically, run the Pro 3 as a slave from your DAW midi clock and set any effect which has a time base parameter to it. Set that parameter to sync and set it an appropriate value. The effect wont sync correctly and starts making warbling noises.
LN
(Pro 3 v1)
Mmmm mine seems to be working fine.
Ive only used a delay so far and it syncs perfectly.
Mine solid with Ableton on Mac.
