Sequencer slide/tie
Sequencer slide/tie
« on: March 13, 2020, 08:33:08 AM »
Is it possible to add slide to certain notes in the sequencer (303-style) ?
I would expect this to work by adding a tie between two notes, with different pitch,  and turning on glide(A) so that i only get the glide for notes that are tied together...
However - it does not seem possible to tie two notes with different pitch
Slew could also be a solution if it was possible to turn on for only some steps
If this does not work, i am seriously considering returning the synt.... :'(
jg666
  • 339
Re: Sequencer slide/tie
« Reply #1 on: March 13, 2020, 09:38:04 AM »
On the Pro2 sequencer you can specify slew amount for each step so I'd be amazed if you can't do that on the Pro3.... or am I misunderstanding what you're wanting?
DSI Prophet Rev2, DSI Pro 2, Moog Sub37, Korg Minilogue, Yamaha MOXF6, Yamaha MODX6
« Reply #2 on: March 13, 2020, 09:43:03 AM »
That would work for me - i will investigate if this is possible on pro3
« Reply #3 on: March 13, 2020, 09:50:49 AM »
Hmmm - does not seem possible on pro 3...
jg666
  • 339
« Reply #4 on: March 13, 2020, 11:43:55 AM »
I found this in the pdf manual but not sure if that gives you the same opportunity as on the Pro2 to alter the slew amount for each step?
« Reply #5 on: March 13, 2020, 02:51:05 PM »
Nope - dosnít seem to help
« Reply #6 on: March 13, 2020, 03:14:57 PM »
Seems like a strange omission with all of the slew, glide, and glide per Osc features. I suppose you could do it by using track 5 and 6 for sequencing notes and using 5 for non glide steps and 6 for glide steps. But thatís a hassle. You should probably send Sequential a feature request.
jg666
  • 339
« Reply #7 on: March 14, 2020, 03:55:48 AM »
It does seem like a very strange omission! It's difficult to tell just reading the manual though.
On the Pro2 when in sequencer mode and you press a step button, it brings up a grid with Notes, Slew and Velocity. You can then alter all of the values in there.
