Sequencer slide/tie
Started by lesterbanjo, March 13, 2020, 08:33:08 AM
7 Replies 24,678 Views
lesterbanjo
Commerce
Is it possible to add slide to certain notes in the sequencer (303-style) ?
I would expect this to work by adding a tie between two notes, with different pitch,  and turning on glide(A) so that i only get the glide for notes that are tied together...
However - it does not seem possible to tie two notes with different pitch
Slew could also be a solution if it was possible to turn on for only some steps
If this does not work, i am seriously considering returning the synt.... :'(
jg666
Full Member
On the Pro2 sequencer you can specify slew amount for each step so I'd be amazed if you can't do that on the Pro3.... or am I misunderstanding what you're wanting?
lesterbanjo
Commerce
Quote from: jg666 on March 13, 2020, 09:38:04 AM
That would work for me - i will investigate if this is possible on pro3
lesterbanjo
Commerce
Hmmm - does not seem possible on pro 3...
jg666
Full Member
I found this in the pdf manual but not sure if that gives you the same opportunity as on the Pro2 to alter the slew amount for each step?
lesterbanjo
Commerce
guyaguy
Full Member
Seems like a strange omission with all of the slew, glide, and glide per Osc features. I suppose you could do it by using track 5 and 6 for sequencing notes and using 5 for non glide steps and 6 for glide steps. But that's a hassle. You should probably send Sequential a feature request.
jg666
Full Member
It does seem like a very strange omission! It's difficult to tell just reading the manual though.
On the Pro2 when in sequencer mode and you press a step button, it brings up a grid with Notes, Slew and Velocity. You can then alter all of the values in there.
