Q about Sequential Pro one
« on: March 03, 2020, 05:59:26 AM »
Someone here owns an original Pro One? How does it behave in Poly mode when you play two notes, and then release both keys? Do both notes continue to sound until the release time runs out, or does one note clip off immediately and only one note (with both oscillators) play during the release time?
I am asking because the Behringer Pro-1 behaves like the last description (one note clips immediately) and I don't like that...
Re: Q about Sequential Pro one
« Reply #1 on: March 04, 2020, 01:13:45 AM »
Maybe I'm not understanding your question, as I don't know the Behringer Pro-1, but the Pro One is monophonic and has no poly mode.
« Reply #2 on: March 04, 2020, 03:11:02 AM »
Thank you! I see now when looking at pictures of the Pro One that it doesn't have the "poly/mono" switch. That seems to be an upgrade made by Behringer then. I know it is a mono synth, but the B Pro-1 has this 2-note paraphonic feature and I assumed it was copied directly from the original.
