Unison - Detune nr Jumps to 16
J_P_P
« on: February 17, 2020, 04:35:32 AM »
I noticed that when you press Unison...if you select the maximum number of Voices - 8 or 16 ...depending on the mode you are, if you change the Detune value from 0,  with the Knob , it jumps to Detune Maximum Value = 16, instead of scrolling through the values 1...2...3...4...5...
However if the number of voices is not the maximum nr of Voices, it goes through the values 1...2...3...4...5...
Anyone else noticed this ?
I only got the Prophet X a couple days ago, and almost imediatly upgraded to Firmware 2.2, so i have no ideia if it happened with previous versions, or not.
Re: Unison - Detune nr Jumps to 16
« Reply #1 on: March 12, 2020, 11:14:38 AM »
Yes I also have this behaviour.
Prophet X, Korg Modwave, Wavestate, Novation Summit, Microfreak, B2600, Akai Force, Skulpt, Uno Pro, Polyend Tracker, Ableton Live and some modular
J_P_P
« Reply #2 on: March 12, 2020, 03:04:47 PM »
It's a Bug...i already reported it to support :)
