Noise in Mute Mode
Started by KoSv, February 11, 2020, 12:51:37 AM
3 Replies 19,457 Views
KoSv
Commerce
I've noticed with some distortion and compressor on ( in mute mode!) I have a significant noise amount.
This noise increases with the amount of lit pads (muting, unmuting) on the T.
Is this known? Or can someone else confirm it?
Greetz, v
Classical piano drilled.
Jazz disillusioned.
Technoid.
Yorgos Arabatzis
Moderator
Full Member
#1
Try doing OSCs and pads calibration with all cables unplugged and see how it goes but to be honest T's compressor and distortion are noisy especially if you're using them simultaneously..Also make sure your sounds are designed with max volume/velocity etc.
There's also a possibility of a hardware voice failure in which case you need to contact support..
The Beatnik Himself
Commerce
#2
Quote from: KoSv on February 11, 2020, 12:51:37 AM
I've noticed some distortion and compressor on ( in mute mode!) I have a significant noise amount.
Greetz, v
I am also experiencing this issue. Did you find a fix? I have recalibrated everything but the problem remains.
I know how noisy the Tempest can be when using distortion/compression, but this noise is noticeably different and happens even when no distortion or compression is applied.
When I'm in mute mode and no pads are lit there is no noise(except for the T's usual hum). After selecting around 6-7 pads(causing them to light up) I start hearing the noise, and by the time all pads are selected the noise makes the unit pretty unusable.
This noise also can happen in Sounds mode if the selected sound is muted. In this situation the noise goes away when the sound is unmuted or I select a different sound that is not muted.
Has anyone else experienced this? Is this expected behavior?
Jim Tanner
Commerce
#3
Quote from: The Beatnik Himself on September 09, 2024, 09:07:45 AM
I've noticed some distortion and Sprunki Game compressor on ( in mute mode!) I have a significant noise amount.
Greetz, v
Noise that appears even when distortion and compressor are off can be caused by hardware noise. Some audio devices, especially those with powerful digital signal processors (DSPs), can generate noise even when effects are not active. This is often due to the internal circuitry maintaining a certain signal level, even when there is no visible input signal. If the device does not have a good noise filter or an unstable power supply, noise can become more noticeable when various effects are active, even when they are muted.
