Hi everyone!
I'm a new proud owner of both the Prophet 6 (keyboard version) and the OB-6 Desktop version, hopefully also a Pro 3 at some point
Still learning how these amazing machines work and while trying to connect them together using MIDI I have encountered an issue which I'm not sure is a bug or perhaps my lack of experience with them.
My setup is super simple, I connect the Prophet 6 to the OB-6 using a MIDI cable, I want to keep both independent of each other when it comes to the knob parameters and everything else, and only send the keyboard/wheel MIDI messages to the OB-6.
I have set the Param Xmit on the Prophet 6 to OFF, and it can no longer control the knob parameters on the OB-6, however my problem is that when I use the program selector buttons on the prophet 6, they still register and change the programs on the OB-6, even though I have disabled Param Xmit from the Prophet.
Am I missing something? the user manual says that when you disable Param Xmit it should only send keyboard and pitch/mod wheel to the MIDI output.
Thank you for your help and attention, and I hope to have some new learning and insights on these amazing synths from this great community!
