Audio inputs at various points would be nice--something I'd hoped for on the Dominion 1 then the MatrixBrute then the Pro 3. I'm guessing it's not necessarily purely a question of cost but one of cost vs value. In other words, is it worth adding if only 3% of users want it?
But the Pro 3's 3 oscillators and noise can be routed out as a CV source at audio rate which you could mangle externally and then feed back in pre-filter. Or did you mean something else?
Yes, I could route the oscillators out via mod matrix and process them... It is getting the audio back in that seem impossible... If I route the oscillators out like that, and route them back in via ext. In, then I would need to be able to turn the oscillators volume down, but still get the audio out the cvs, otherwize I would get a blend af original and processed sound... I do not know what happens at the CV outs if I lower the volumes of the oscillators, but I would assume the went down in volume with the oscillator level controls.
If I could just patch in a eurorack filter someway, I would have much more use of the cv functionality... Even if it was only filters... Would be really fun to try out ms20, arp and other eurorack filters with the PRO3 especially because you can use the 4 outs to control the given filter from the PRO3 itself.
If i have to usr 3 of four outs on getting the oscillators out, then there will only be 1 cv left to control anything on the module which is a real shame.
An alternative way could be to route the main out to the filter, but then you would need stereo filters and eventually also bypass the fx engine.
Would be so much easier if there were a few insert jacks on the back for this.
If more than 3% want this we will not know if anyone does not request it... This was the hope I had with this thread... That people debate hardware wishes instead of only os update requests, so that maybe Sequential might get a better picture about what people might want in the next PRO4 or whatever...
