can i trigger tempest beats from a sequencer (cirklon)
« on: January 27, 2020, 01:33:03 AM »
so i want to assemble a bunch of beats and then fire them off from the cirklon rather than the tempests pads ...is this possible??...cheers
Re: can i trigger tempest beats from a sequencer (cirklon)
« Reply #1 on: January 27, 2020, 06:43:06 AM »
i think its a no ...there would have to be a midi cc command to select beats but there isnt ...i guess the cirklon has to do it all instead...
« Reply #2 on: January 27, 2020, 02:12:14 PM »
No need for a CC message..If the Cirklon can send a Midi note message then by switching “Pad to Note Mode” to Beats you can fire them off from it.You can change that in T’s preferences inside “Midi remote pad play” menu.Just make sure you set the correct “Remote Pad In” channel.
Check the manual page 70.
« Last Edit: January 27, 2020, 02:14:29 PM by Yorgos Arabatzis »
