Sequential Pro 3 Introduction
Started by patrickdsp, January 15, 2020, 03:54:39 PM
69 Replies 219,570 Views
patrickdsp
Commerce
DevonB
Commerce
Keyless version coming eventually in Desktop or Rack format?
Guest
Quote from: DevonB on January 16, 2020, 04:48:33 AM
I doubt it. Never happened for the Pro 2. If anything I think we might see another instrument (either another poly synth or possible Tempest successor) before we see a desktop/rack format version of the Pro 3.
creativespiral
Full Member
Nice intro/demo video!   I'm excited.  Inclusion of the Moog T-Ladder filter is a great choice (hope its included in next Poly release too) - and the hybrid oscillator combo is nice.
That 32 slot mod matrix with 171 destinations and the sequencer is gonna allow for some extremely deep sound design and mod sequences.  Preparing for the bleeps, the creeps and the sweeps.
Sound Sets:
hybridanimal
Commerce
Exciting stuff!  Microtuning out of the gate or will we have to wait on this one like the Pro2??
Robot Heart
Full Member
Quote from: hybridanimal on January 16, 2020, 03:03:43 PM
It's a standard feature on the Pro 3.
SEQUENTIAL | OBERHEIM
Paul Dither
Moderator
Full Member
musicmaker
Commerce
#8
Do hope for that. Rack size would be great because desktops are so unhandy large . The form factor of the P12M is ideal because it then can still be put on the rack shelf taking minimal space when not used for knobbing and just MIDI use. Could remove the sequencer buttons to create space for desktop/rack and edit seq/ via the screen. P12M ID was very different than the P12 keys but still easy to use and it is still in retail. Too bad it did not have MIDI sample dump standard to load samples or wave-tables, so hope this will. (Not prop. format like Nord among others. Standard MIDI is a big reason to keep buying Sequential products. Q: To which Sequential/DSI products the 2 Analog Oscs can be compared to ?  Perhaps wooden side panel as an option for the std. version ?
katavist
Commerce
Quote from: Robot Heart on January 16, 2020, 04:27:35 PM
Yessssss!!! Very nice. GASsing for the SE now...
Paul Dither
Moderator
Full Member
Quote from: musicmaker on January 17, 2020, 12:03:22 AM
The VCOs can be compared to the ones of the Prophet-6. However, they are not identical:
Shape mod (known as PWM if applied to a pulse waveform) now also affects the triangle and sawtooth shapes and anything in between triangle and sawtooth, sawtooth and pulse. On top of that, not only the shape mod parameter can be modulated, but also the shape selection parameter that allows you to continuously morph between triangle, sawtooth and pulse shapes.
Paul Dither
Moderator
Full Member
#11
Plus: the tuning can now be chosen on a per program basis. It's no longer a global parameter only.
jdt9517
Full Member
I can't justify a new synth right now, but this is definitely on my GAS list.
Full Member
I am shadow...
I hope someone at Sequential will answer this question:
What audio sample rate are the mod matrix working at? If you can send oscillators out the CVs via mod matrix I assume it must be at least 44.1khz?
I think I remember that the Prophet 12 ran at a slower rate, and wanted to know if this has been improved on the pro3?
OG3
Commerce
Is the SE a limited edition as well?  Or can we expect equal availability as the standard pro 3?
jg666
Full Member
https://www.youtube.com/watch?v=or6CpbGRLFY
Not sure if it's very different from the other videos but here's one from the UK store Andertons with Dave presenting again :)
Paul Dither
Moderator
Full Member
