The pots are going to have some wiggle since they aren’t bolted to the chassis. Not sure what would cause the squeak—maybe the pot rubbing against the chassis or the pots themselves. I’d suggest contacting support.
Quote from: guyaguy on January 13, 2020, 11:53:33 AMThe pots are going to have some wiggle since they aren’t bolted to the chassis. Not sure what would cause the squeak—maybe the pot rubbing against the chassis or the pots themselves. I’d suggest contacting support.Thanks for the response! I contacted support and they said that the noise should not cause any issues.
Quote from: Hampus on January 13, 2020, 01:04:07 PMQuote from: guyaguy on January 13, 2020, 11:53:33 AMThe pots are going to have some wiggle since they aren’t bolted to the chassis. Not sure what would cause the squeak—maybe the pot rubbing against the chassis or the pots themselves. I’d suggest contacting support.Thanks for the response! I contacted support and they said that the noise should not cause any issues. Nice answer. I’m surprised they didn’t mention anything about how lucky you are to have additional free tone generators. Seriously I wonder if your machine was stored in a dusty or dry or hot room or simply felt on the face. As guyaguy said they are not bolted, just soldered hence pretty fragile. Other explanation is poor quality of parts which falls into support. Why don’t you return it ?
