Anybody use Ableton Live w/ the Pro 2?
ARNK
  • 124
    • Returning to Zero
« on: December 28, 2019, 10:16:33 AM »
Did you create a template for Ableton? If so what did you use or how'd you go about it?
Thanks
« Last Edit: December 28, 2019, 10:19:36 AM by ARNK »
Re: Anybody use Ableton Live w/ the Pro 2?
« Reply #1 on: January 02, 2020, 07:35:40 AM »
I do!
I'm a huge user of the CodeKnobs Pro2 VST.
It integrates everything other than sequencer data.
No VST currently pulls sequencer data so I've made peace with rarely using the sequencer.
I'll use it the odd time when I'm just making a patch from scratch with only the Pro2 on and no session open.
But in terms of template, you dont need one per se.
For a while I had the above VST already loaded on a track... but sometimes ran into issues where I was working on a patch that I havent saved yet and then the VST pings the Pro2 automatically with whatever saved setting is on.
I dont have the VST in the template and manually add it when I'm 100% sure I've saved whatever patch I'm working on locally on the Pro2
« Reply #2 on: November 09, 2021, 11:45:44 AM »
If you own Max 4 Live there is a beautiful editor to do everything inside ableton with pro2.
download -> https://maxforlive.com/library/device/5129/dsi-pro-2-control
Tutorial: https://youtu.be/Ffe7OaJo338
