I have a Ob6 module and i love it !
However i'm facing this weird issue.
I use an Elektron Octatrack to sequence and control the module.
Everything works fine except for the fact that when the Octatrack send a program change message, the Ob6 will change the program : the display will show the correct patch BUT in fact, the sound is not exactly the same of this patch.
For instance, i send a program change to patch 133. Ob6 shows 133 on its display, but the sound is a bit different. When i manually press 3 on the Ob6 panel, the sound is finally correct. It's like the Ob6 changed the patch, but not the sound coming out is not totally reflecting the current patch until i manually press the patch number.
Any clues about what's happening ?
Thanks
