Edit Sample indicates that the sample's default loop points are being overridden in the preset. Typically, a sample's default loop is carefully adjusted at a sample-accurate level to provide a nice smooth loop. When overriding the loop start / end in the Prophet X, on the other hand, you get much less precision and should normally enable crossfading to mitigate the effects of the noticeable discontinuity that will almost surely emerge.
