How to Make a Single-Cycle Waveform
Started by chysn, September 27, 2015, 04:52:01 AM
5 Replies 170,376 Views
Moderator
Full Member
If you want to create single-cycle waveforms for your Evolver, but don't know how to do it, this is where to find help!
You'll need audio editing software. Discussion of the best audio editing software is beyond the scope of this post, but it may be discussed later in the thread. For now, I'll give two recommendations. For PC, Mac, and Linux systems, Audacity is a very robust, and free, waveform editor. You may download it at http://audacity.sourceforge.net/download/.
For iOS devices, I would recommend TwistedWave. This is very full-featured. When I bought it, it was in the ten-US-dollar range, but it's very nice.
First, record your full waveform, or open an audio file. Once you have the file created, it'll look something like this:
If your original waveform is in stereo, you'll want to convert it into mono. To do this, click on the caret in the upper-left corner of the waveform window and select "Split Stereo to Mono."
Once you have them split, go ahead and close one of the two waveforms.
This waveform is much too big to be used in an Evolver. You want to grab a single "cycle" of that waveform. To find a cycle, you need to zoom in. For the Mac, you press Command-1 to zoom in. To find the key binding on your platform, open the View menu at the top of the screen. Try it... zoom into the waveform a few times:
As the waveform gets longer on the screen, you'll need to use the scrollbar at the bottom of the screen. (You can also resize vertically at the bottom of the waveform window.) Keep zooming until you can make out a single distinct data points:
Now you can extract a single cycle of this waveform. Find a point where the wave is at the center line and ascending. Then, find the next point where the wave is as close as possible to the center line and ascending. Click on the first point, and drag to the second. The point you choose may be arbitrary, or you may experiment with different points. In my wave, I've chosen a range more or less at random:
Now, at the top of the screen, go to Edit > Remove Audio > Trim. On a Mac, this is Command-T. Only your selected single-cycle portion will remain.
Export your file with File > Export. Audacity gives you a lot of options for saving the waveform in different formats. But the default format should be "WAV (Microsoft) signed 16 bit PCM." Evolver waveforms are transferred as 16 bit signed PCM.
Now the wave is prepared to be converted to the Evolver system exclusive format for sending to your Evolver. You may bring your WAV files into a utility like WAV2Evolver http://wav2evolver.dsi-lifeboat.com for conversion to system exclusive. Information on this process is in another thread on this forum: http://forum.davesmithinstruments.com/index.php/topic,38.0.html
Questions or comments? Talk below!
Prophet 5 Rev 4 #2711
MPC One+ ∙ MuseScore 4
proteus-ix
Jr. Member
Quote from: chysn on September 27, 2015, 04:52:01 AM
...Once you have the file created, it'll look something like this:
What happened to the pics?
And... why create your own waveforms?  Demos of how to use this to do something substantially different than what's included?  (Don't mean to be devil's advocate, just don't really know how to benefit from the process)
Moderator
Full Member
Quote from: proteus-ix on October 10, 2017, 01:10:27 PM
I let that domain expire. I updated the URLs to the alternate domain. Thank you for pointing it out.
The specific context here is creating single-cycle waveforms for the purpose of transferring them to an Evolver as custom waves. There might be other reasons to do it, but that's why this tutorial is here.
Soundquest
Full Member
This is a nice program (the one chysn has posted above) and I use it quite a bit.  Cymbals seem impossible on subtractive synth.  I ended up with something metallic, not quite a cymbal though.
https://www.youtube.com/watch?v=qVeaU5HbH5c&t=49s
proteus-ix
Jr. Member
Quote from: chysn on October 10, 2017, 07:43:56 PM
Great, thanks!
Ok I understand that, although I meant my question more generally in terms of how it's useful for sound design - why do you want custom single-cycle waves?
What can you/ do you plan to do with your custom waves that you can't with the included ones?
How do you know what sort of wave is good for what?  Etc.
Soundquest
Full Member
Proteus-ix,
I use the custom made waveforms for when I want to mimic a sound of an instrument (or any object that makes sound).  While combining various square, saw, sine waves can get you close most of the time, it can be tricky to end up with a wave form exactly like that which you are trying to mimic.  So this process of "drawing in" your own wave shape gets you in the realm right off the bat.  Of course, simply experimenting with your own shapes independent of attempting mimicry, is also useful if you want something different than the norm for the basis of your patch.  So, yes, very useful for sound design.
