hiiii!!!! im trying to sync lfo with cubase 9, when i use the sequencer its ok but when i turn it of the lfos dont sync with the midi notes in cubase... is that normal....my ather synth is doing it perfect, where ever in the project i start the locator the lfos are sync... i have pro 2 midi clock mode in slave and clock cable in midi port wich is the cable that i have connect the pro 2 with cubase and i have also try setting in cubase nothing happend....can someone help? do you have the same problem? is it a bug? or im doing something wrong ?
