Hello,
I read quite a lot the internet (and this forum) about issues with sending midi from the sequencer of the Rev2 to a DAW.
I know it is possible but the problem I have at the moment is strange and its driving me crazy
What's going on:
I connect the Rev2 via USB to Computer (iMac)
The Rev2 is in Multimode: Midi channel 11 (Layer A) & (automatically) 12 (Layer B) with each their own audiotrack
In Cubase (Pro10):
I created 2 MIDI channels (11 & 12) and 2 audio stereo tracks.
When I play and record notes manually on the Rev2 it wil be recorded in Cubase BUT when I want to record a sequence from the REV2 in Cubase, I can hear the sequence playing on each layer on its own audio track (that works, great)
But there are no notes recorded (no midi activity at all).
The only way I can record a sequence in Cubase is by switching to
Local On.
The sequence is recorded but not seperated in each of their midi channel (11 layer A and 12 layer B) but stacked together with a lot of double notes. (Tried in Split A/B mode, Stack A/B mode etc.)
In the REV Global menu:
MIDI out ARP+SEQ on
Multi-Mode on
Midi clock mode: slave
I tried almost every combination:
switching MIDI Thru Active on and off (in Cubase)
USB MIDI and MIDI with Cables (midi in/out)
CC and NRPN (Rev2)
Track MIDI monitor on and off (Cubase)
Only MIDI in routing active while recording (Cubase)
So what could it be?
regards,
Patrick
