Power-cycling makes OB-6 forget which patch I was on?
« on: October 14, 2019, 11:51:41 AM »
Hi
Sorry if this is a dumb question but....
When I turn my OB-6 on it always shows patch 000. So if I was using Patch 002 today, then powered the OB-6 down at teh end of the day. When I power it up tomorrow I will see Patch 000 and not 002.
Is this normal behaviour? Or have I accidentally turned something on/off somehow.
Thanks for any advice (bit of a novice user here)! :-)
OceanMachine
Re: Power-cycling makes OB-6 forget which patch I was on?
« Reply #1 on: October 14, 2019, 12:58:15 PM »
Yes, it's normal. Every time you go into the globals it will remember the current patch you're on upon turning the unit back on.
« Reply #2 on: October 21, 2019, 06:08:41 AM »
Thanks for your reply. I am still a little confused though.  'Every time you go into the globals it will remember the current patch you're on upon turning the unit back on.' does you mean I can turn something on in Globals that will cause my 0B6 to remember which patch I was using next time I power it on?  My OB6 always powers up on patch 000 no matter which patch I was using before I powered it off.
OceanMachine
« Reply #3 on: October 21, 2019, 08:01:33 AM »
No, simply going into globals will do the trick.
« Reply #4 on: October 21, 2019, 09:33:59 PM »
Another way of saying 1000 Eyes' solution is 'when you're on the sound you want it to start up on, press the global button twice in a row.'
Hopefully you got that already, but just in case ;)
T8, Tempest, OB6, Prophet X. 8DIO Prophet 5 add-on, Sample Packs from Lady Gaia (synth waveforms) and Modulatable.com (Moog One.)
« Reply #5 on: November 03, 2019, 03:19:29 PM »
Brilliant, got it now, thanks! :-)
