left right volume imbalance
« on: September 17, 2019, 09:40:54 AM »
Hi guys,
i've found a little problem on my unit.
The output is a little bit unbalanced.The right out is 1 or 2 db louder.
I've tried to calibrate the filters but the problem is always there.
Anyone with the same issue?
Re: left right volume imbalance
« Reply #1 on: September 17, 2019, 03:10:28 PM »
Not on mine.
What I like to do anyway on every patch I create is to set my first modulation source to DC and destination to Pan to easily control the position of my bass, pads and twinkles in the panorama of my loop.
What issue is that balance offset causing for you?
« Reply #2 on: September 18, 2019, 12:16:35 PM »
Great.
So with dc you can control the panning!
Anyway i've tried to isolate the problem plugging my unit in different ins and to flip the right ch and the left ch and i'm pretty sure the problem is the synth
ARNK
  • 124
    • Returning to Zero
« Reply #3 on: September 19, 2019, 10:13:19 AM »
Hi guys,
Nope, mine does this too. I made a post about it a while back and never followed up.
I thought the issue was the way the patch was programmed but they all seem to lean right more.
Could someone w/o the issue post an image of the peak values being exactly the same in stereo mode? Iíll share pics of what I mean in a bit.
« Last Edit: September 19, 2019, 10:16:44 AM by ARNK »
ARNK
  • 124
    • Returning to Zero
« Reply #4 on: December 26, 2019, 07:35:34 PM »
For me, controlling Pan by setting the DC Offset to -5 centers all of the patches, but I don't know of a way to apply this all patches in batch mode. Can you not hack a Fixed Mod?
