so, how to read NRPN table in the manual?
« on: August 05, 2019, 05:19:44 AM »
hello community,
i'm trying to understand how to read NRPN table in the manual, unsuccessful at the moment.
would like to understand it without reverse engineering capturing messages.
so, the questions are:
— what are the numbers in Parm, A & B columns ?
— are they related in any way to NRPN number MSB / NRPN number LSB / NRPN value MSB / NRPN value LSB message structure?
also, a little feature request to Sequential: please add a description how to read NRPN table to the future revisions of manuals, or put this information somewhere on the site, because column names like A & B are at least counter-intuitive.
thanks in advance.
« Last Edit: August 05, 2019, 05:22:58 AM by chaocrator »
Re: so, how to read NRPN table in the manual?
« Reply #1 on: August 05, 2019, 10:17:04 PM »
ok, let's assume that no one knows, because (as i can see from search results) everyone asks only about particular solution for particular software.
i already figured out that number in column A appears to be NRPN number LSB.
edit: decrypted B column — it is for combos (Edit B button on front panel active), and the number is given in MSB+LSB form.
so, the only thing i still don't understand is the Parm column.
« Last Edit: August 05, 2019, 10:43:52 PM by chaocrator »
« Reply #2 on: August 06, 2019, 12:38:21 PM »
Here's an old post from one of our software engineers that should point you in the right direction:
https://tetradev.blogspot.com/2010/03/nrpns-part-1-basics.html
You'll find links to NRPNs parts 2 and 3 on that page as well.
SEQUENTIAL | OBERHEIM
