Gated Reverb?
Gated Reverb?
« on: August 04, 2019, 02:32:46 PM »
Does anyone know if there is a way to get a 80's style "Gated Reverb" effect with the Reverbs?
Shaw
  • 1110
Re: Gated Reverb?
« Reply #1 on: August 04, 2019, 03:58:20 PM »
Use an envelope (with a slightly longer relates than you VCA) to control the Reverb mix amount.  That could approximate the effect.
Re: Gated Reverb?
« Reply #2 on: August 08, 2019, 06:15:07 PM »
Thank you!
Shaw
  • 1110
Re: Gated Reverb?
« Reply #3 on: August 08, 2019, 06:24:45 PM »
Really should have proofread my response... Use an envelope (with a slightly longer RELEASE than your VCA) to control the Reverb mix amount (so that the envelope’s return to 0 on release will change the Reverb mix to 0).
