Does anyone know of a workaround to get the gated sequencer to have the gate stay open for the whole duration of the note length, rather than the default 50%? I have opted to use the gated sequencer instead of my external sequencer so that I can use the external to transpose it, however the 50% gate time means that the sound of the sequences are not exactly the same - using amp env release doesn’t achieve the same results as a 100% 16th note gate time, mainly because it results in polyphony. I tried this in unison with all voices set thinking that might be a fix but notes still sustain with the release.
Slew doesn’t help either as all the notes in the particular sequence I’m running are the same pitch.
Any creative suggestions would be much appreciated :-)
Greg
