Since a lot of companies are doing reissues or updates of older classic analog synths there's a synth that I'm shocked Korg didn't attempt or perhaps Dave himself collaborating with another Synth legend to bring a newer version of a forgotten classic back:
ARP Quadra.
You could split this synth in 4 different zones (hence the name)
(From Vintage Synth)
"Bass synth, Poly synth, Lead synth, and String synth. It is quite good at emulating each of these sounds and can function in any of its four modes at a time with the ability of layering the different sections! Sounds you create in any of the four sections are instantly recalled from memory by the push of a button! There are 16 program patches for storing your sounds. Other major features are the incredible phase shifter, tons of balanced audio outputs for each section, dual portamento controls and a superior arpeggiator
The Bass synth section is monophonic and can be programmed to occupy the lower two octaves of the Quadra's 5-octave 61-note keyboard. The bass sounds pretty good and has 16' and 8' presets each for Electric and String Bass sections.
The string section is based on the Omni II String synth. It sounds excellent and implements a phase-shift effect that is sort-of like a chorusing effect that thickens its already great string sound.
In Polyphonic synth mode there are more effects available such as sample-n-hold and the phase-shifter. String and Poly Synth sections have 8' and 4' Polyphonic Waveform Generators each along with a preset called Hollow Waveform.
In Lead synth mode the Quadra becomes a two voice screamer with aftertouch sensitivity in the upper octaves of the keyboard! It's duophonic (like the Odyssey). Get a bass sequence going, switch over to another section and play along! "
I first discovered the ARP Quadra when I got my LP of the Escape From New York soundtrack and noticed the gear list. In addition to the Prophet 5 a lot of the sounds came from the ARP Quadra. Allan Howarth said that it was used in the main riff of the opening titles (layered with a Prophet 5) as well as the arppegiated sequence underneath. Him and John Carpenter used it again on Halloween II and Christine.
I think the ARP Quadra seems to have been forgotten. I have no idea why. I'm not sure how well the Korg Oddessy was received and while I do appreciate their $500-600 mini key analog synth (which do give great sounds) I wonder why they haven't looked into creating a full sized analog synth.
Or
Since Dave collaborated with Roger Linn on the Tempest and now Tom Oberheim on the OB-6 is it possible he could collaborate with other Synth manufacturers? For example since Yamaha and Dave worked a deal where he can use the Sequential name again is it a possibility they could collaborate to bring us an updated version of the CS-80? A DS-80 If you will.
While a modern CS-80 would be mind blowing, I think an updated ARP Quadra is something that's a bit more versatile than another polysynth with no splits or layers and the idea of 4 splits, layers with multiple sequencers (With external sync since the original didn't have this), better Midi, better memory and 5 or more octaves (This has to be the case since there's so many splits) would justify having this as a welcomed addition to anyone's rig.
I know Dave isn't big on reissues but even if he took a similar approach and created his own version (A Pro 2 on bass, Morpho 4 on the poly section, etc etc) it would still be breathtaking.
Thoughts?
