Update that lets us send track 1 midi data out
« on: July 12, 2019, 07:19:46 PM »
Hey Sequential Team and CBMD!
I love this pro 2.
I'm trying to send the midi out of track one on the sequencer (without the copy to Track 2 work around)
I know this synth is now discontinued but if there could be one last update for this synth... this would bring the sequencer into 2019.
I've tried connecting the pro 2 to my computer via both USB and Din midi, no change.
Arpegiator sends fine to my daw, sequencer does not.
Is this a permanent hardwiring thing or is there some update for this in the realm of possibility.
Much love,
Stephen
Re: Update that lets us send track 1 midi data out
« Reply #1 on: July 12, 2019, 07:36:54 PM »
I think its worth adding that one of the main reasons I believe this is possible is that I own the soundtower librarian and it is somehow able to pull the note data from sequencer track 1 and store it. (Screenshot attached)
http://www.soundtower.com/pro2/index.html
If Sequential could send us off to Pro 2 retirement with this update it would be a gamechanger <3 <3 <3
« Last Edit: July 12, 2019, 07:38:26 PM by mcnallys »
monoliths
  • 1
  • THE WORLD BEYOND
« Reply #2 on: November 30, 2019, 01:24:21 AM »
Not sure if you ever got your answer. I struggled with this one last night, and found a work around. You have to copy the Track 1 info to another track (i.e. Track 3). On Track 3, make sure the destination is set to Midi Out 1. The annoying part is that it didn't copy the velocity information as well, so I had to manually add the values in for each note. You can find out to do this all here:
https://www.sequential.com/wp-content/uploads/2016/04/Pro-2-OS-1.2-Addendum.pdf
« Reply #3 on: January 14, 2020, 10:01:30 AM »
Just saw your reply now! Thanks man. Will give that a go.
ARNK
  • 124
    • Returning to Zero
« Reply #4 on: April 26, 2020, 03:38:07 PM »
I can get midi notes to record but they don't resemble the pattern from Track 1 at all.
ARNK
  • 124
    • Returning to Zero
« Reply #5 on: April 26, 2020, 03:39:08 PM »
Has anyone had better luck sending midi out from the sequencer?
