USB noise
USB noise
« on: July 09, 2019, 04:48:23 PM »
I don't know why but somehow when i plug the USB cable from the Rev2 in the Mac, a lot of noise is generated on my audio bus. It's kind a constant noise, very perceptible.
The noise keeps sounding even if i turn the Rev2 off. It only goes away when i unplug the USB cable from the Rev2.
Is there a way to avoid  this ?
  • 2168
Re: USB noise
« Reply #1 on: July 09, 2019, 04:56:19 PM »
It may be that you are not using a shielded USB cable... it's most likely due to some ground-loop or something... I have a REV2 connected via USB directly into my Windows PC, and i get absolutely no noise at all...
Re: USB noise
« Reply #2 on: July 09, 2019, 10:59:31 PM »
I had similar issues. I couldn’t fix then on the USB side but the sound card input being balanced I used TRS. Not the best solution though since I now have a 6dB attenuation but the noise is gone.
Re: USB noise
« Reply #3 on: July 11, 2019, 12:39:43 PM »
I have posted info on isolating and fixing ground loops here:
https://forum.sequential.com/index.php/topic,2629.msg28837.html#msg28837
There should be plenty in there to find a solution.
SEQUENTIAL | OBERHEIM
Re: USB noise
« Reply #4 on: July 11, 2019, 07:35:29 PM »
I also had a similar problem when I first got a MacBook Pro connected to my Kronos.
Turns out it was the power brick.  I unplugged it from the laptop and the buzzing sound went away.
Moog One <> Prophet Rev2 16V <>  Andromeda <> Kronos 61 <> Nord Stage 2 HA76 <> Integra 7 <> Minilogue XD module <> Blofeld desktop <> Behringer Model D <> Minitaur <> Slim Phatty <> Matrix 1000 <> Micron <> Privia PX-5S <>  MODX7 <> TG77 <> ASM Hydrasynth <> Perform VE <> FCB1010
Re: USB noise
« Reply #5 on: July 14, 2019, 05:07:08 PM »
Thank you !
