These samples are great as waveform modulation source, or using "granular" while moving the Center Sample or what you want!!!
It's a kind of Swiss knife!
4 more to come for the community
Sorry if the stuff is not perfect in quality or even in taste....
Have mercy 😋 it's just music!!!
Good night everyone.
I tried to open the zip file, but I am asked for a password...
That’s the file you load into the PX.
It’s asking for a password because it was created with 8dio’s utility, but your PX can open it.
Thanks. The file structure of this utility is far from intuitive. Managed to create the proper folders and place the files into them, but didnt realize I had to rename each instrument since all of them were labeled 02. Did this, and tried to repeat the procedure again, only to find that the X suddenly wont recognize the USB stick which it updated from only 10 minutes previously, and turning the unit on and off does not solve the issue. I cant even reformat the USB stick since it claims there is no USB stick in there. The Mac recognizes it as always.
I love the X to death, but this sample loading procedure drives me nuts.
I feel your pain. As I point out, Luigi is using the 8dio utility which is far from perfect. It’s almost shameful.
Anyway, I’m not sure if you can rename / renumber these sample sets. I feel pretty certain that you can move them to different folders, but renaming / renumbering might not be possible.
As for your USB drive, re-format it on your Mac, then re-format it in your PX. That should get you rolling again.
