A: B: in Globals menu
« on: June 27, 2019, 11:29:34 AM »
Can't find any information about what these numbers at the bottom left of the globals menu. A: cycles between 1-7 and B: always stays at 7. Something about voice allocation?
Re: A: B: in Globals menu
« Reply #1 on: June 27, 2019, 12:21:31 PM »
Yes indeed. It is showing which voice is currently assigned to which layer. It's not documented in the manual because it is an add-on since the last few OS updates.
« Reply #2 on: June 27, 2019, 12:32:37 PM »
Gotcha. Can you explain any further or point me toward a resource? It seems I'm only getting 7 voices out of layer A even though I'm not using a stack or split.
« Reply #3 on: June 27, 2019, 02:39:14 PM »
Assuming you have a Rev2  8-voice version (8/16 voice version is displayed on power up), the count starts at 0, so 8 voices for layer A should be 0 - 7. If this is not what you're seeing please contact our dedicated technical support:
support (at) sequential.com
SEQUENTIAL | OBERHEIM
