PXToolkit 1.0 Available Now
Re: PXToolkit 1.0 Available Now
« Reply #60 on: July 30, 2020, 09:36:31 PM »
Wowzers thanks so much. I sincerely appreciate the contribution of tech and tech support that seems to permeate these threads as I look through. A sign of good character. Is there anywhere you accept donations, Gaia?
-Oh I should have explained the issue is when I'm developing drum racks for which the key is not really necessary... and rather I just want a wide selection of kicks n hits across the entire keyboard. I think based on what you told me though I can navigate it now.
-Yes I normalize the samples using Fission (which honestly I expected more from)... but still sometimes too quiet for some reason. Then I don't know how to raise the volume without it "clipping". I'd like a better editing program that could detail edit hissing and unwanted audio ranges as well. Something like audacity but much more fine tuned... anyone know of Anything?
-As for threads, I meant any good threads... especially technical modulation threads. I was just trying to avoid delving into all the posts when someone might already know of the golden threads!
--P.S. Id love to hear your work Lady Gaia. I bet you've got some interesting stuff. Cheers.
Sound Vision
« Reply #61 on: July 31, 2020, 05:22:28 PM »
I really like the community that has built up around this synth, it's true, and am happy to have played my part.  The work I've done on PXToolkit really is just a gift to other owners, so no worries there.  While I may set up a fund to pay for Thinkersnacks hosting some day, I'm currently very well employed and don't want to muddy things by creating any perception that I'm working a side gig.
I suspected it might be percussion focused, but you're quite right that the premise is much the same - you just want to set the root note to the key you plan to trigger the sample with, and can limit the range to just that key.  It should be trivial if you name your samples using a consistent convention and drag them all in at once.  PXToolkit will only create a range when there are gaps between adjacent samples, and even if you drag in one sample at a time it will happily make room by reducing existing ranges.
Audacity was certainly the first thing to leap to mind in the way of free tools, and it does have a compressor which is invaluable for trying to match volume or squash excessive peaks the keep a sample from normalizing to the level you'd expect.
Hah!  I wish I had the time to take my rough ideas and pursue them.  Music is very much a passion that has always taken a back seat to my career.  I had expected to retire (today, actually!) to focus on music but with the present uncertainty in the world and travel being utterly impractical it just seems insane to put aside a lucrative career.  So I'll keep it it for a little longer before music can take center stage in my life.
At the moment I don't have a single keyboard instrument where I'm living while waiting for the United States to collectively wake up and take COVID-19 seriously enough to get things under control.  That's kind of a bummer, but I have had plenty of time to plan my secondary studio space here, and I've handed off my CAD drawings for a custom desk to the folks who are busy making it a reality.
« Reply #62 on: August 05, 2020, 10:24:13 PM »
Would there be any issues with also loading content from SampleRobot into the PX as well as keeping some of the content loaded by the PX Toolkit? I havenít loaded into the PX from SampleRobot yet so Iím not sure if you can specify the category, number etc and more importantly advises you if thereís already content on the instrument number you are trying to save to.
« Reply #63 on: August 06, 2020, 12:28:57 PM »
So long as you don't use the same bank / category / instrument number you won't have any problems.  PXToolkit and SampleRobot both follow the same specification from Sequential regarding the import format requirements, and the Prophet X treats them identically.
When you do an export in Prophet X format SampleRobot asks for the bank / category / number information.  You need to keep track of what you've used before AFAIK.  There's really no way to know what you've already installed on the instrument, but PXToolkit tries to at least suggest unused numbers if you consistently export everything to the same folder on your Mac or PC.  I don't believe SampleRobot provides any assistance with this, but something might have changed in more recent versions.
« Reply #64 on: August 06, 2020, 04:04:56 PM »
In SampleRobot, if you export to the sample directory/folder, it will warn you if you've already exported something in that category / bank / number and make you select another location. If won't, however, suggest other locations. You'd need to look at the folder to see what's there. And, as Lady Gaia mentioned, you'll need to track what's on your Prophet X/XL.
Jeff KellemóTypeface designer, Composer, Pianist, Analog synths, Dancer
« Reply #65 on: August 06, 2020, 05:21:20 PM »
Wonderful thanks all! I donít have much on there right now so it should be easy enough.
