New user question
jconway3
  • 30
  • Rev 2, Pro 2 & OB6
New user question
« on: May 06, 2019, 01:52:06 AM »
Hi all
Can someone please explain the relationship between the names on the pads in 16 sounds mode with the actual sounds on the individual pads. I have discrepancy between the two. Also how it’s the folder and load sound visible at the outer edge of the display relevant.
I apologise in advance if these are basic quest but I am struggling with interpreting the manual
OS etc are all up to date
Thank you
Re: New user question
« Reply #1 on: May 06, 2019, 02:33:01 AM »
You have to be more specific on that...
jconway3
  • 30
« Reply #2 on: May 06, 2019, 10:15:49 AM »
Hi thank you for your reply. Here goes
So let’s say I’m looking at the 16 sounds screen and in the display and see a sounds name displayed on each of the 16 boxes on the display. Now let’s say  box number 1 says TAMB, I would expect to hear a Tambourine sound if I hit pad one but instead I hear something else like say a clap or any other sound. How can I ensure that the 16 boxes on the display are a true reflection of the sounds loaded on each pad.
I hope this makes some sense
« Reply #3 on: June 15, 2019, 04:02:53 AM »
you can change the name of the pad, in pads screen hold shift then the 3rd knob  (Sound Type) above the oled will change the pad  name. there is a limited number of usable names. they dont always make sense in the presets.
« Last Edit: June 15, 2019, 04:04:24 AM by antaine »
