Some days ago, the volume of my Rev 2 started to drop to somewhere near zero after some time of use. When I turn the master volume to maximum i can barely hear it.
Rebooting or Re-Calibrating the Prophet has no effect.
The only possibility I've found to bring it back to normal is to re-start the audio interface and then move the master volume knob of the Prophet, then it's working again (for some time).
One more thing I found out: When I switch the audio interface on, all Midi Out LEDs on my midi interface (Motu Midi Express 128) for some reason light up for a short time.
When I unplug the midi interface while powering up the audio interface, the prophet won't return to normal volume after moving the volume knob.
The problem also occurs on the headphone out and on the second output.
What could be the problem here?
Thanks and best regards, Chris
