Sequencer stuck on MIDI note?
« on: April 08, 2019, 05:33:49 PM »
Hey guys,
For some reason lately my PEK seems to have a MIDI note stuck to the sequencer. Regardless of where I route the sequences, even if I have them unassigned completely, this single note seems to trigger.
I don't think it's anything in my INIT preset as I've tried a few different ones and they all have the same thing. Any ideas? Thanks!
Re: Sequencer stuck on MIDI note?
« Reply #1 on: May 03, 2019, 11:07:14 AM »
ScottBrio,
Not sure I understand the issue from the video.  Stuck note still after power off and on?   Remove all midi cables and then try.
« Reply #2 on: May 25, 2019, 12:56:18 PM »
when no destinations are selected it just opens the vca and you hear the osillators at their default pitch, you can check that by using VCA level to see if this sounds the same except the VCF not beeing triggered. Destiantion "All OSC Note" or so should send note values again.
Hope this helps,
Martin
